Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tie Rods = one time use?
Old 08-10-2012, 10:50 AM
Silver Surfer's Avatar
Silver Surfer Silver Surfer is offline
More machine than man
Last journal entry: bwaahhaahahaaahhaa
I removed the centerlink from my C-10. I went to reinstall it and when I tighten the nuts on the tie rod, the stud just spins. I assume they were designed this way so that they must be replaced after you remove the nut? Is there any shame in just replacing the inner tie rod, or should I get inner, outer, and adjustment sleeve?
