Tie Rods = one time use? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2012, 09:50 AM
Silver Surfer's Avatar
Advanced User
Last journal entry: Test Drive (finally)!
I removed the centerlink from my C-10. I went to reinstall it and when I tighten the nuts on the tie rod, the stud just spins. I assume they were designed this way so that they must be replaced after you remove the nut? Is there any shame in just replacing the inner tie rod, or should I get inner, outer, and adjustment sleeve?
Old 08-12-2012, 05:00 PM
bigdog7373's Avatar
Of course it's fast
Just replace what's broken imo
Old 08-12-2012, 05:26 PM
Irelands child's Avatar
If it's a fairly new and in good shape tie rod end, clamp it tight in the taper fit, make sure the threads on both nut and stud are clean, and bolt it in place. Even a brand new tie rod end can spin in its socket if it's not tight in the taper and the threads are a bit distorted or dirty.
Costs of rodding, rat rods, time wasting... flynbrian48 Hotrodders' Lounge 28 09-01-2009 10:47 AM
Any Completed Hot Rods/Customs/Street Rods in or near Atlanta Georgia? THE PHANTOM 1443 Hotrodders' Lounge 1 06-02-2009 05:38 AM
Replacement boots for tie-rods? 11echo Suspension - Brakes - Steering 2 01-06-2009 08:10 PM
opening conecting rods to use Small jouornal rods with a large crank eatonde Engine 1 12-08-2008 04:22 PM
Tie rods rubbing into the insides of tires...? 72Nova Suspension - Brakes - Steering 5 10-02-2002 09:18 PM
