Tie rods rubbing into the insides of tires...? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2002, 07:35 PM
Post Tie rods rubbing into the insides of tires...?
I got a 72 nova with drum brakes all around.
I got 14x7 "6-vent" 2nd generation Rally's on the front and back.
Alingments don't help.
Spacers make my steering wheel wobble too much.
Should I change spindles? or rim sizes?
thanks
b
Old 09-26-2002, 08:18 PM
Post
I had a '72 a few years ago...put the 14x7 rally's on it....same exact problem!!
I ended up putting a couple 1/4" spacers on each side..never had any vibration problems. I thought the spacers were hack, so I ended up ordering two wheels from Wheel Vintiques with a 1/2" offset from stock..
Old 09-26-2002, 10:30 PM
CARGUY's Avatar
Post
i had the same probelem on a car, so i got a grinder, and ground the end of the tierod down flat. it worked for me
Old 09-29-2002, 05:03 PM
Post
I guess I just have too much appreciation for the steering...It is pretty important to me.
I once saw a guy grind a steering shaft down to a smaller diameter, to help clear a header tube....
[ October 02, 2002: Message edited by: SirSpeedy ]</p>
Old 09-29-2002, 05:38 PM
Post
sir speedy, how much did the 2 wheels cost you?
did the 1/2 inch offset work well?
Old 10-02-2002, 09:18 PM
Post
I'm thinking around $45 each. That was a few years ago.
Early Wheel, Stockton Wheel, and Wheel Vintiques all sell custom diameters, widths, bolt patterns, and offsets of the GM rally wheel.
