TIF TP-90 HVLP - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2002, 02:44 PM
Post TIF TP-90 HVLP
Has anyone used this HVLP system. I'd like to hear some fedback on it.
Old 07-16-2002, 05:09 PM
Post
Only way to go nowdays. Saves lots of paint and doesn't spread a lot of overspray all over the place. DO use a good mask and respect your neighbors. Urethane is nasty stuff. It will stick to a wet surface. Like the inside of uour lungs!! You can buy a fairly cheap gun that will work as well as a high priced one. Handling is easier too, but takes a little getting used to. Good luck.
Old 07-16-2002, 06:10 PM
Post
Are you referring to any HVLP system or the one that I mentioned? I'm thinking about purchasing the T.I.F.F. TP-90.
I have some sort of Craftsman HVLP gun but I don't like the way it works. ZIt does not seem to be a true HVLP to me. It oprrates at 60 psi and uses 8cfm of air. The TP-90 uses 60CFM and operates on 4psi.
TP Tools Turbine HVLP Systems Scode68 Body - Exterior 10 06-10-2011 09:05 PM
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
one giant orange peel flamedfordbronco Body - Exterior 14 06-20-2007 09:04 PM
TP HVLP Turbine system ram1 Garage - Tools 2 07-02-2006 12:34 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
