TIG Cooler - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-28-2012, 10:32 PM
SuthnCustoms's Avatar
Crazy Ole Ironhead
Subscribed to this thread...Buyin a brand new HTP Invertig 221 soon to have around for aluminum work and other TIG needs,i will also be interested in building my own cooler setup
  #17 (permalink)
Old 01-29-2012, 07:27 AM
garyroushkolb's Avatar
Last wiki edit: How to find an electrical drain Last photo:
When I built mine I used a transmission cooler, aluminum water tank, and a fountain pump that was medium size. It needs to be pushing the water after it is cooled not pulling heated water and the stream needs to be about 1/8 inch in diameter that shoots about 1 foot horizontally (farmer tech) for pressure. I used this a few years with no problems except the noise. The trans cooler didn't even need a fan unless I was welding heavy aluminum at 200 amps for a long time.
I'd still be using it if it wasn't so loud that I had trouble hearing the phone ring over it.
  #18 (permalink)
Old 01-29-2012, 08:22 AM
Originally Posted by acourtjester
HI
Here is a tig cooler I built and saved a bundle.
Buy a procon pump from ebay (new $50.)
I bought a 1/3hp motor and modified it to have a fan blade on the other end.
If you build one have make sure you only run it at 50 PSI or you can blow the torch lines.
have fun
Tom
Hey Tom
Thanx for sharing your homemade rig.
I'm looking at building a cooler for my Miller also.
So, I looked up a ProCon pump on ebay. There's alot available from 500.00 to less than 50. Which one do you have??
Daryl
  #19 (permalink)
Old 02-05-2012, 03:27 PM
Kool Hand Tig
I have used baby tigs many times for field work where access limits equipment with no overheating. Aluminum is totally different. For most shop work buy an ac/dc water cooled unit with high frequency. There are still older millers and lindie's out there that will give you all you need in a welder. From the projects you've shown there should not have been an overheating problem with a water cooled unit. This usually happens on thick aluminum. If the torch starts getting warm slow down and let the water circulate. Just remember to keep your project hot, it will melt easier and let your torch stay cooler. A good welder can be a costly item but will give a refund every time you use it.
  #20 (permalink)
Old 02-11-2012, 08:21 AM
Last journal entry: Start over
heavy metal welding
A couple of tricks I've used for thick aluminum when the machine just isn't big enough. Obviously, heating the part will help but sometimes isn't practical.
You can use helium as a shielding gas. It'll make a hotter weld pool. Bad thing is it's expensive, you have to use more of it and it's less stable. To fix that, I've run a mix with argon. You need 2 flow meters and a splitter. I'll run 5-10 CFH He & 10 CFH Ar. Helps with the above problems. There's also the trick of running 100% He and DCSP. Everything has to be cleaner than clean and absolute control is a must. Not for amatures.
  #21 (permalink)
Old 02-11-2012, 09:42 AM
Helium
Thick aluminum is a challenge and using Helium does make for quicker heating and increased penetration. When Lindie invented the Tig welding process they called it Heliarc welding because Helium was the primary shielding gas. Other gasses became more practical and Heliarc Became Tig, just be sure not to get Helium use to fill balloons. I use a hand held propane torch from the hardware when welding thick aluminum such as heads. All these tips are good to know and thanks for the post. There is no substitute for experience.
  #22 (permalink)
Old 02-11-2012, 10:03 AM
gow589's Avatar
the Clever Turn Signal
Before building the cooler I just had to stop every now and then to let it cool.
To properly let the torch cool as soon as I stopped I pulled the torch apart to help is cool.
  #23 (permalink)
Old 03-01-2012, 11:11 AM
barry425's Avatar
Last journal entry: Barry's Vega
cool your TIG torch
Just hook a solenoid to your torch and have it turn on when you start the arc. hook the inlet of the solenoid to your tap water and the outlet to your sink drain. It doesn't use that much water and it is always cool water going to the torch. Another advantage is no noise. I did it this way with my Miller Aircrafter (450 amp machine).
using a trans cooler for a gas cooler? biohazard_81c10 Hotrodding Basics 2 09-05-2011 02:09 PM
Need for an oil cooler 65malibuSS Engine 11 01-06-2011 02:17 AM
External Trans Cooler, Radiator Cooler, or both? 2004R & 383 SBC Cousin_Joe Transmission - Rearend 1 02-27-2008 09:10 AM
Can I use a trans cooler only without a radiator cooler? supercab78 Transmission - Rearend 5 04-14-2005 01:46 PM
Oil Cooler jrm123180 Engine 5 08-27-2004 10:22 PM
