Tig and Mig questions for new buyer. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2010, 12:35 AM
Hi all,
I have been looking at buy a Tig or Mig for body work on cars. I have used a mig on steel tube etc but never on car panels and see someone useing a Tig and the welds look so much smaller and flatter so probably better as they would require less dressing. I noticed some Tigs listed as aluminum or not aluminum, whats the difference and how do i tell it its not stated?
How thick of steel per amperage can i do with a tig?
What should i know about buying a tig welder etc?
(there is a chance i might buy a 200amp mig aswell if the need arises)
thanks
Old 06-27-2010, 06:00 AM
BOBCRMAN@aol.com's Avatar
A Mig welder is great for sheet metal work. It heats the surrounding metal less and warps less. With practice the bead can be controlled to very small. Most better machines also have "spot" weld capabilities.
A Tig machine for steel only has no "high frequency". AC This is needed on aluminum for cleaning of the weld and better starting of arc..
Old 06-27-2010, 08:05 AM
cranky1's Avatar
Just stuck
If you want to learn more about TIG or MIG, you might check out U-tube for TIG and MIG vids....there's a ton of them on there and some of them are really good.
Old 06-27-2010, 11:36 PM
Silverback's Avatar
Boost Retard
They're good for different things...
I would argue that 90% of what the typical person would want to weld with car projects can be done with a MIG, but there are things that TIG specializes in. There are people that do somewhat specialized work that will tell you "I can do everything with a TIG," but i will say that most of the time I can do without my TIG, but there are times I wouldn't be without my MIG. Yes, there are things that I couldn't get finished without a TIG, but I could fit them up and even tack them with a MIG and take them to a local shop to have them TIGed if I had to, where the other way around there are some things that I'd have a very difficult time doing with a TIG and just wouldn't be able to get done.
Basically, if you just need it done or if speed is an issue you need a MIG, but as things get more precise and "high end" then a TIG gets more important.
Old 06-28-2010, 09:31 AM
302 Z28's Avatar
I would agree with all comments about the MIG being used for most all welds associated with auto work. I would also add that a TIG is going to be quite a bit more expensive than a MIG.
Vince
Old 07-02-2010, 11:01 AM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
For TIG if the machine has AC Weld output then it can do aluminum. Some machines are DC only, for example I have a Miller Maxstar 90 that is a DC only TIG that's strictly for sheet metal. Miller now makes maxstars that are 150 Amps and do Stick or Tig and weigh around 10 pounds, which is great if you only need to do light work and have limited space. I would suggest poking around on Miller and Lincolns websites to get an idea of the machine's they offer in both categories (MIG AND TIG) and see which fits your needs best.
Need cheap MIG TIG advice KenCam Body - Exterior 9 04-30-2007 03:05 PM
Mig or Tig frank speigel Garage - Tools 20 01-20-2006 07:41 PM
Mig to Tig conversion? Billy Boy General Rodding Tech 8 01-14-2006 12:28 PM
Mig, Tig, Arc, or Oxy-Acetylene? SkyMan9600 Body - Exterior 5 03-02-2004 09:06 AM
MIG and TIG welders Cowtown Punk General Rodding Tech 6 07-31-2003 11:42 AM
