I did that last year.
Made it real fun to weld with my torch dribbling all over my lap. I tried tape, then i tried tape and putting shrink tubing over the tape and shrinking it tight. It was never fully sealed. I had thought about trying to find just the plastic tube from mcmaster carr or another industrial supply house, but got lazy and just bought a new torch. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
You got lazy????? Not the Soul of Gilroy.....Ohhhhhhhhhhh I can't believe it. Ha Ha Ha, Lmao......Seriously you did the right thing by getting a new torch...some things are just not meant to be fixed and I think thats one of them.
I did save it though..along with the one I pulled out of the dumpster at the machine shop...someday I'll get motervated and make 1 good one out of the 2 trash ones.
That torch will have soul Mikey
no to h2o
Just try turning off the water. I weld all day at 125 amps plus and my torches don,t get hot. Ask any Boilermaker and he,ll tell you water cooled is built in complexity .
thanks, Clint |
I tried that myself when the patches weren't working.
When I did that with my weldcraft WP20 it was very unhappy. The lead actually melted through the outer casing. I have a WP 18 that would probably have withstood being run waterless @ 125, but my smaller one would not. I use the smaller torch for every day work. I wonder what KA67_72 has for a torch. BTW, a friend of mine is a boiler certified welder. He bought a little tig for use at home that came with an air cooled torch. He hated it. He couldn't wait to get a smaller, water cooled torch. I myself have used the air cooled ones for several hours at a time and found that the handle gets very uncomfortable. "Built in complexity" is not really what comes to mind when I think of water cooled. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike; 11-06-2006 at 10:36 AM. |
tig torch repair
The only way to do it right is buy a new power cable and also buy a spare for the shelf. There is several places on the net that sells welding supplies and you can find the cheapest source. I'm not kidding about buying a spare cable.
The last time I put a hole in a hose I made a repair so I could finish a job with water bed glue and vinyl hose that covered the hole about 6 inches both ways and still seeped. I have several power cables with holes in them that maybe I can put new hose on but since the price on the net is much more reasonable it's now not worth the effort. I have a cover on my hose that is supposed to protect them from damage but the best thing is just be careful. While on the subject does anyone have a source for inexpensive water pumps for cooling units, mine broke a gear and I need to replace the water pump. It's really surprising how much pressure that it takes to push water through a tig torch and lines. You can see the line flex when you turn on the pump. |
I have a 350 amp Weldcraft. I was hoping someone would know how to repair it. It's just a small pinhole. If I knew what the hose was made of, I could figure out what solvent to use to repair it. I'm too cheap to spend a $75-$100 on a new hose.
Thanks, Kevin |
In the quest for knowledge I called my welding supply house owner who in turn called weldcraft.
The hose is vinyl They called it "traditional vinyl" later, mikey
tig torch repair
try this link http://store.weldingdepot.com/cgi/we...t/WP18-25.html the entire torch is $81, I'm sure the cable won't cost that much. Been there, tried that and failed every time. I have seen power cables repaired by replacing the whole hose and reattaching the cable parts but never patched a hole successfully.
| Recent Garage - Tools posts with photos |
| Harbor Freight TIG | oldred | Garage - Tools | 54 | 02-22-2009 05:00 PM |
| Mig to Tig conversion? | Billy Boy | General Rodding Tech | 8 | 01-14-2006 12:28 PM |
| Good quality TIG welder which one?? | sevt_chevelle | Body - Exterior | 8 | 01-05-2006 06:58 PM |
| Henrob(sp?) and jewler's torch users | baddbob | Body - Exterior | 9 | 12-06-2005 04:16 PM |
| TIG vs. micro torch? | rpaulsen | Body - Exterior | 3 | 03-03-2004 03:41 PM |
