Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tig Welding Aluminum
Old 11-12-2004, 11:26 AM
Beenaway2long's Avatar
Beenaway2long Beenaway2long is offline
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Zonk,
When you grind your tungsten, be sure to use the wheel ONLY for tungsten. Otherwise you'll get a porous weld, and it will have all sorts of black in it. You may want to use a smaller tungsten, too. Radiator tanks are awefully thin.
Jeff
