Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tig Welding Aluminum
Old 11-12-2004, 01:06 PM
Beenaway2long's Avatar
Beenaway2long Beenaway2long is offline
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Depends on the angle of the torch tip. I stick mine out 1/4". The tighter the tip to the cone, the harder to see what your welding. Harder to strike the arc, too. Could you even stike an arc, if it were inside the cone? You'd really have to "pedal it" to get a high enough arc.
