Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tig Welding Aluminum
Old 11-13-2004, 08:36 AM
Meteor's Avatar
Meteor Meteor is offline
Cool Tig'n Aluminum
Zonk, here's a couple more cents worth from a non-expert. I use the shortest electrode extention that I can get a stable arc with. The shorter the better since it helps to keep contamination away.
Also depending on how tight the joint access is, I will play around with different nozzel diameters. I like to use a small diameter tungsten and nozzel on thin materials.
I don't do much aluminum so when I do I spend more time practicing on scrap before I get to the objective...lol.
Good luck
