"TIG" welding gloves vs MIG welding gloves. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2011, 07:30 PM
Back a few years ago I was on a welding supply truck and he guy had these beautiful welding gloves. They were WAY thinner leather than the ones I had used all my life and weren't clumsy like the thick ones I was accustomed to. They were labeled as "TIG" welding gloves, can't see why they wouldn't work with the MIG so I gave them a shot. Now, this was a number of years ago (five or more) and though they have gotten a couple of burns thru them they are well worth the slightly less protection if you ask me.
Do any of you guys use anything like this?
Old 04-02-2011, 07:43 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
We had them at the mine all the time . A pair followed me home. I also love them. They aren't thick enough for insulating against heat with heavy stick welding, but are fine with the 3/32' rod that I use in my shop. They are actually thin enough that you can fell what you are holding. Besides, I couldn't get my thick fingers in any of the regular welding glove that we had. I gave away all the regular welding gloves that I was carrying in my truck, for my welders, when I retired. BTW... Thanks for the reminder, I need to get down to the welding supply to get another pair of TIG gloves. Also try them for grinding. Saves on the shirt sleeves.
Old 04-02-2011, 08:16 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I use those kind for welding but use the thicker ones for plasma cutting..I also use a different hood for plasma cutting..
Sam
Old 04-02-2011, 08:19 PM
If I hadn't found them by accident I would have never known, they really are much better. As Abu on the Simpsons would say "Oh yes, they are almost sensual"
Old 04-02-2011, 08:35 PM
327NUT's Avatar
I have the same Tillman gloves, bought them on Ebay for $12. Eastwood also sells them...and yes they are very comfortable.
Old 04-03-2011, 07:20 AM
Last journal entry: Time vs money
Will have to try them. Don't like the thick gloves so I use cotton gloves with the rubber nubs ($1.95 / pair). So far no issues with them catching fire. No good regarding heat so I keep pliers close by. I do go through shirt sleeves quickly when grinding so will try these there as well. Thanks for the info.
I should post a picture of the blue jeans I bought at a Salvation Army store for $4.00. Figured they would be good shop pants. They had the bottom of the legs freyed. Don't weld with freyed anything on. Caught fire and I didn't notice until the flames were knee high. Should have video taped it. Me dancing around with a MIG gun in one hand, cut off pliers in the other trying to put out the flames with one foot while dancing on the other.
Old 04-03-2011, 07:37 AM
Call me lucky or stupid. I seldom wear gloves mig welding or plasma cutting. I am big into clamps and pliers for holding or moving hot metal. When my son bought the TIG, he picked up a pair of TIG welders gloves that look more like driving gloves. They are made from Nomex with a tight fitting wrist band to keep sparks from getting under the glove material. I have tried them but don't trust them to pick up a piece of hot steel.
Trees
Old 04-03-2011, 08:45 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i used to have a pair of those, they made me feel like a "3 musketeer"
Old 04-03-2011, 09:43 AM
Wiki Edits: 27
finger sleeve
I've seen finger sleeves you can slip over your finger on your tig gloves for added heat protection when you slide your hand along the hot material heating up the pinky finger. . depends on how you hold the torch and what finger gets too hot and how many you need. .
Old 04-03-2011, 11:13 AM
Ahh, interesting.
Old 04-03-2011, 01:14 PM
Silverback's Avatar
Boost Retard
they are much better for light use, but I doubt that they would survive that much heavy use. I typically wear through the trigger finger on my right hand first mig welding, then the matching thumb. I also have the issue with the back of my hand/pinky finger overheating if I'm running some long, hot beads, but I rarely wear through that area, more insulation would just help me keep going longer...
Old 04-03-2011, 04:12 PM
Trees
Call me the same.. Sometimes I wear one on one hand just to hold while I weld with the other.. No welding gloves though, just your usual work gloves..
Of course, I don't grab the metal afterwards.
Old 04-07-2011, 01:23 AM
bentwings's Avatar
bentwings
I use the Tilman tig gloves all the time. At the last TIG shop I would go thru a pair a night in production welding.
There actually is an even better quality pair with softer leater. I use these at the racecar shop. they are used only for TIG never any other process and never for handling material other than while welding. I keep the worn out ones and double them up for material handling.
For TIG welding you need clean gloves with no oil,dirt or grease on them. When they get dirty they are work gloves and you need a new pair.
You can not weld with bare hands either. The oil and dirt on you hands will contaminate the weld wire. It's hard enough to pass weld tests without adding to the difficulty.
Also don't kid your self, the ultraviolet from welding is just as bad for the skin on your hands as it is on the rest of you.
Old 04-07-2011, 09:53 AM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Originally Posted by bentwings
'SNIP'
X2.... I was thinking the same thing .
Old 04-09-2011, 05:49 AM
deadbodyman's Avatar
Wiki Edits: 11
Not only that but welding without gloves can ruin a perfectly good manicure.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Strange thing happening with my clear "solvent pop"/"fish eyes" ? myfamiliacc Body - Exterior 35 02-16-2013 07:18 PM
wiki pages: "How to rebuild an engine", "Window removal/installation" Jon Hotrodders' Lounge 0 07-11-2006 12:44 PM
Mechanics Gloves?? SimS Garage - Tools 14 02-28-2006 12:35 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 01:13 PM
