Tight skirt clearances? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2013, 11:38 PM
If your running a tight squirt clearance will/can this cause HP loss? I'm right at or close to 0.001" ( 1 thousands) I'm running Hyper Sealed power pistons.
Old 04-28-2013, 11:49 PM
techinspector1's Avatar
Wiki Edits: 326
It's hard to tell if you mean skirt, squirt or squish. Piston to wall clearance can be run as tight as 0.001" with certain cast and hyper pistons. Counsel with the manufacturer of the pistons. Squish should not be run closer than 0.035" on a SBC.
Old 04-28-2013, 11:53 PM
BOBCRMAN@aol.com's Avatar
Skirt clearance is tight on hyper pistons. .001" is common on normal use street
Whoops slow typer
Old 04-30-2013, 07:49 PM
Tight skirts? Gotta say I love 'em.
PatM
Sometimes, ya just can't resist.
The Following User Says Thank You to PatM For This Useful Post:
Richiehd (05-01-2013)
sorry for this but: 454 or 496 ?? tight tight budget Berres Engine 3 03-26-2011 01:56 PM
ARRGGHH, chipped a piston skirt! flynbrian48 Engine 14 01-30-2008 07:07 PM
billet rocker hold downs clearances tight help??? charger528 Engine 2 09-25-2007 06:51 PM
Long skirt SBC pistons fierosum Engine 9 01-16-2004 08:02 AM
Fender Skirt Replacement Banbear Body - Exterior 0 10-14-2003 08:36 AM
