tight tie rod ends - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2009, 05:42 PM
tight tie rod ends
The last two cars I have finished (one with a mustang 2, and one with a straight axle with a 525 box with cross steering) have both been very hard to steer and wouldn't return to center. Caster checks out in both and I am starting to thing tie rod ends. I have used cheap ones. Has anyone experienced this. Will the tie rods eventually loosen up? Should I pop for some Moogs? Or???
Heim Joints, Tie Rod Ends Jsup Suspension - Brakes - Steering 20 03-01-2009 09:00 PM
Tie Rod Material - Part II cboy Suspension - Brakes - Steering 6 07-26-2007 07:40 PM
Rod length discussion, split from previous thread seriousracer Engine 11 06-29-2007 12:27 PM
Tie Rod ends luckyfasteddie Suspension - Brakes - Steering 3 11-26-2006 02:05 AM
Tie rod ends (converted GM to rack) Andym Suspension - Brakes - Steering 3 08-29-2003 03:38 PM
