Tight Tuck headers Patriot - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2013, 06:57 PM
Anyone used this style header? Looking to get the most steering shaft room available.
Patriot Exhaust H8052 Patriot Tight Tuck Headers
Old 06-17-2013, 10:27 PM
techinspector1's Avatar
Wiki Edits: 326
Before I'd pay money for a fosdick unit like that, I'd hunt around in the boneyards for some stock cast iron exhaust manifolds that exited the pipe where I wanted it. Those Patriot units won't make any horsepower and neither will cast iron manifolds, so you may as well do it the cheapest way.
The Following User Says Thank You to techinspector1 For This Useful Post:
61panhead (06-18-2013)
Old 06-28-2013, 12:56 PM
Patriot H5062 headers
OK so I bought the Patriot H8062 headers and I really like them!!! Love the room for the spark plugs.. BUT, they come out too far from the block. The exhaust pipe will be difficult to run by the steering rod. On to the next set...
Old 07-01-2013, 01:59 PM
evolvo's Avatar
Heathen
That side shot shows the flange several inches above the frame rail, running exhaust should be no problem IMO.
Old 07-01-2013, 02:02 PM
The exhaust would be no problem but it will be directly in the way of the steering shaft. I sent them back and looking for a good block hugger header.
Old 07-01-2013, 02:51 PM
vinniekq2's Avatar
Its a low HP engine,I guess what ever fits easiest?
Old 07-01-2013, 03:08 PM
ahhhh.. ok thanks I guess
Old 07-01-2013, 03:17 PM
vinniekq2's Avatar
If you want headers,contact Jere Stahl or you might have to make them.what kind of car?
Old 07-02-2013, 12:47 PM
327NUT's Avatar
Here's a set of Sanderson CC5's that were in a '32 Ford, they should fit your application. It's a picture of a picture, kinda crappy but you get the idea.
The Following User Says Thank You to 327NUT For This Useful Post:
61panhead (07-02-2013)
Old 07-02-2013, 12:53 PM
That's what I'm looking for!! Thanks for the picture!!!!
Old 07-02-2013, 02:32 PM
sedanbob's Avatar
I got my headers from Speedway - they called them tight-fit. Mine are for 'D' port heads, but they have the same headers for regular port SBC heads.
ID:	75377   Click image for larger version
The Following User Says Thank You to sedanbob For This Useful Post:
Old 07-17-2013, 06:43 PM
Bought a set of Sanderson CC-1 block huggers. Looks like they will work! Plus there's room for the plug wire boots.
Old 07-17-2013, 07:26 PM
vinniekq2's Avatar
what size are those primary tubes? they look very small
Old 07-17-2013, 07:34 PM
1 5/8 tubes 3 " collector
Sanderson CC1-5/8" header set for small block Chevy engines. Fits 1927 and up vehicle applications.
Old 07-18-2013, 10:46 AM
Grand Master of the Universe
Like Sedanbob's, S/S Blockhuggers from Speedway.
Name:	steering done comp.jpg
ID:	75797   Click image for larger version
Name:	steering in wood comp.jpg
Patriot Headers H8013 cdminter59 Engine 4 01-04-2013 01:13 PM
Patriot Headers lt1tyrell Engine 15 08-26-2009 11:08 PM
Patriot Clippster Headers lt1_performance Engine 0 12-30-2007 09:48 AM
Patriot Headers theclaw1 Engine 2 12-07-2007 05:54 PM
Patriot Headers for a Tri-5 Stroker56 Engine 1 03-02-2006 08:55 PM
