tig'ing stainless - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2005, 06:11 PM
Dmon's Avatar
New Member
tig'ing stainless
I just got a 180sd and I am attempting to tig Stainless. 304 stainless with 308/308L filler. My beads are a terrible black. Is this just too many amps or am I doing something wrong?
Old 01-07-2005, 06:31 PM
4 Jaw Chuck's Avatar
Either you are getting no shielding gas at the tip or your pressure is too high. Too high a pressure will cause turbulence that mixes atmospheric oxygen into the shielding gas.
— Han Solo
Old 01-07-2005, 08:12 PM
poncho62's Avatar
Wiki Edits: 5
moving to "garage"forum.........
Old 01-07-2005, 09:08 PM
daimon1054's Avatar
I have done SS with a mig and if you don't use the right gas it will discolor. It can be sanded and buffed out but it will discolor.
Old 01-07-2005, 09:49 PM
Dmon's Avatar
New Member
The gas was set to 20 cfh. I was using a lens/shield combo from Radnor. These were sold to me at the time of the 180 buy. The cup is kind of a tapered to a smaller outlet. They claimed less gas and the electrode could protrude farther.
Old 01-08-2005, 01:44 AM
New Member
how far is you stick out? to far?
I use about 6lb, when welding stainless
are you pulling or pushing.. you might already know but you need to push it..
Old 01-08-2005, 07:05 AM
Dmon's Avatar
New Member
I was using 3/32 2% thorieated electrode, and it was protruding about an 1/8". I was also pushing. It kind of sounds like I was using too much gas flow. I will try it agian tomarrow with less.
Old 01-08-2005, 04:57 PM
Dmon's Avatar
New Member
Ok Here is a pic. The black bead ( if you could call it that) in the upper right corner was a before I made these changes. I changed to 1/16" electrod TH. Reduced gas to 12 and put the stock cup that came with my 180. Set my max amps to 70. I had another person look at the machine to tell me the amps. Most of the time I averaged about 22-26 amps.
Old 01-08-2005, 05:43 PM
daimon1054's Avatar
Change your gas, if you are not using tri gas you will discolor.
Old 01-08-2005, 05:48 PM
Dmon's Avatar
New Member
Tri gas with a tig?.
Old 01-09-2005, 08:49 AM
daimon1054's Avatar
You can uas any gas you wish but if you are using argon on SS it will discolor. As said the weld is fine and can be poished out.
Old 01-09-2005, 04:10 PM
Dmon's Avatar
New Member
That is strange I posted this question at millers fourms and there is a gentelman that laied a bead on ss with argon it was not discolored. Look at this.
http://www.millermotorsports.com/mbo...tachmentid=908
Old 01-09-2005, 09:17 PM
daimon1054's Avatar
I can only tell you what I have done and read? I am sure a pro welder could do things that I would not dream of.
Old 01-09-2005, 10:35 PM
New Member
at the machine shop they use 100% argon.. all I ever used on my own stuff too... JMO
Old 01-10-2005, 07:49 AM
daimon1054's Avatar
OK I just called a friend who was certified in the Navy he said you more than likely have contamination and he is thinking oil.
1 clean the metal with a good degreaser and possibly even alcohol
2 check with your supplier and make sure they have not had problems with oil in the gas
He said if it was a lack of gas problem then you would be consuming the tungsten or the weld would be pocked and that I was wrong argon should be fine.
