tilt column for 36 Chrysler - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2005, 07:38 PM
jaxhome's Avatar
Building a 36 Chrysler 2 door sedan airstream streetrod. Looking for a chevy donor car for a tilt column. Anyone out there found the right car with the right tilt column for your 36?
Old 10-23-2005, 09:47 PM
As the Moderator.........I deleted your double post of this question.....
As for the column......
A lot of rodders around here use the Chevrolet/GMC van tilt column. It looks good, has the shift indicator on the column, has a neutral start switch and no ugly key .
Old 10-24-2005, 07:25 AM
acr acr is offline
My 1936 Plymouth rod has a GM tilt wheel that is supposed to be out of a late '70's/early 80's GM van. As Deuce said it works great. acr
Old 10-24-2005, 09:58 AM
jaxhome's Avatar
how to measure length of steering column
I see guys advertise tilt columns that have been shortened for a streetrod. Where do you take the measurements for the column? Just end to end? Also, you mention 70's to early 80's van columns should fit. What length are these?
Old 10-24-2005, 08:55 PM
acr acr is offline
Mine is stock length,the factory sheet metal collar where it bolted to the van floor was cut off. I'll try to measure in the next day or so.
How the $%$%#$ do I get this tilt column apart...... Hotroddder Suspension - Brakes - Steering 5 06-08-2005 09:45 PM
tilt column in 55 studebaker studebakerclyde Engine 2 03-07-2004 07:40 AM
GM tilt column Busted Knuckles Suspension - Brakes - Steering 3 11-07-2002 07:11 PM
tilt steering column sweethome18 Hotrodders' Lounge 4 10-23-2002 07:35 PM
