Tilt column rebuild
Hi again Im new here and yesterdays post is in the wrong section and is not getting seen. Ive got a 70s tilt GM column in my 37 ford. It is tilt and column shift but has no key in the column. I need to remove the shift sleeve. Im down to it but it wont slide over the U-joint for the tilt. the shaft has to come out. i thought it would just slide out with a little help but its not??
