Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tilt column rebuild
Old 11-26-2006, 01:48 AM
Triaged Triaged is offline
Got a pic? I'm not following where you are stuck at
Have you pulled the sheet metal sleeve that covers the upper housing off yet? just slides off but often needs some persuasion
If you need to take the u-joint thing apart you need to "tilt" it 90deg in order for the plastic thing to come out. Have you taken out the tilt hinge pins yet?
