tilt column shift indicator - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2011, 05:35 PM
I just installed a tilt steering column from a 1993 Astro in my 49 Chevy pickup. It worked out very well. Also found a nice shift indicator & pointer for a 3 speed 700r4 from an old 80's van from a junkyard. The indicator mounts ok on the upper part of the column, under the steering wheel, which always remains stable. My problem is when the wheel is tilted up or down the pointer is moved away or closer from the indicator letters, depending on the tilt position its never in the right spot? Is there anybody that has solved this problem? Any advise on how to approach this??
Does anyone have a lokar dash mounted shift indicator powerrodsmike General Rodding Tech 2 12-31-2007 10:43 PM
Gear Shift Indicator ARPEE General Rodding Tech 2 09-13-2006 07:36 AM
need help on converting column shift too floor shift . jody chevelle Electrical 1 11-29-2005 08:29 PM
Tilt Column for 66 GMC? 66GMC Suspension - Brakes - Steering 9 06-14-2005 07:53 PM
Column shifter indicator with overdrive? 70 sbc Transmission - Rearend 2 02-16-2003 05:54 PM
