Tilt front end? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2005, 03:31 AM
Tilt front end?
I'm installing a one piece glass front end on my '73 Laguna. I have decided to cut the rear fender sections. This should allow me to tilt the front end without having to pull it forward slightly hence requiring a more complicated hinge mechanism. Anyway, as I am a complete novice when it comes to body work I was wondering what methods are used to permanently attach the rear fender sections to the car? I have an idea of how this is done but just wanted more expert advice that will give a more professional look.
Old 04-07-2005, 09:15 AM
willys36@aol.com's Avatar
Wiki Edits: 21
'37- '42 Willys have the same problem - the fenders extend well into the cowl section and in addition the external hinges are in the way of a tilt one piece hood. Thus the typical fix is to cut off the tips of the fenders like Centerline describes. However, I have a friend for whom I built a '42 Willys pickup and he wanted a tilt one-piece 'glass hood but didn't want the fenders cut. I designed a mechanism that slid the hood forward about 8", then tilted forward, thus no cut fenders! It has a couple of 3/4" roller bearings on a bracket in the center of the hood at the cowl that roll in a channel that is welded into the cowl. Then there is a 2" square steel tube in each frame horn that has a bar (made of plow steel for strength) with 4 of the roller bearings that slide in and out very easily. At the other end of those bars the hood is attached with a swivel pin. finally, I added two scissor bars that attach to the frame (or radiator support) and the inside of the hood that restrict the hood from opening too far.
http://hotrodders.com/forum/t38408.html
front end too low mopar 36 Suspension - Brakes - Steering 21 11-19-2008 05:44 AM
tilt front end locaters fire power Body - Exterior 0 02-10-2004 12:54 PM
Tilt front end on late 60's Impala or Chevelle?? black66 Body - Exterior 1 05-13-2003 12:25 AM
front end tilt using my all steel front end old c10 head Body - Exterior 5 05-02-2003 02:45 PM
Tilt front end Al Body - Exterior 5 02-12-2002 11:45 AM
