Tilt front end - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2002, 03:36 PM
Al Al is offline
Post Tilt front end
I am building a 49 Willys sedan delivery and want to make a tilt front end. Any ideas on hinges, latches, etc?
Old 01-29-2002, 08:59 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
Talking
I don't know about the hinges, but i always thought it would be cool to use power-trunk latches for the hood.
JB
Old 01-30-2002, 11:53 AM
New Member
Post
I'm into the Ford thing and haven't paid a lot of attention to other Marques that use front tilts. But, front tilts are real common on 54 to 56 Ford F100 and Dennis Carpenter Enterprises sells a kit for them. You can find the company on the web. You could get some product literature from them and copy the basic geometry and techniques. I am sure I could figure one out from a picture and use somthing like suspension bushings as fulcrum points. I would guess that the callenge is in finding a strong point down low below the grill opening to which you could attach the fulcrum for the body and to an adjacent frame attachment point. Another thought is a forward tilt hood. For these you can use Saab or BMW fulcrums and latches. I have seen some of these done well.
Old 02-01-2002, 07:52 PM
New Member
Talking
Summit Racing Products lists hinges for tilting your front I think they are about $100. Bud
Old 02-11-2002, 10:02 AM
Wiki Edits: 49
Thumbs up
I designed an electrically operated all steel tilt front end for my pro-street 41 Chevy coupe. You can see pics and a drawing of the design on my web site below.
The hinges are 3/4" rod ends and the system is held closed by the 12-volt linear actuator from Ball's Rod & Custom, which operates the mechanism. Works like a champ and really impresses people when you just flip a switch on the dash and the front end opens.
Old 02-12-2002, 10:45 AM
F-1Rodder's Avatar
Post
Use mercruiser power pistons and their electric pump to raise and lower it. The pumps are a dime a dozen from old worn out I/O drives. They are made from Stainless.
Front end tilt on 64 Impala- pls help Cruzin_64 Body - Exterior 2 07-28-2007 09:59 AM
Tilt front end arellanojoey Body - Exterior 1 02-17-2006 09:07 PM
tilt front end locaters fire power Body - Exterior 0 02-10-2004 11:54 AM
Tilt front end on late 60's Impala or Chevelle?? black66 Body - Exterior 1 05-12-2003 11:25 PM
front end tilt using my all steel front end old c10 head Body - Exterior 5 05-02-2003 01:45 PM
