tilt front end -reverse polarity electric switch??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2002, 07:33 AM
Post tilt front end -reverse polarity electric switch???
I appreciate all the help everyone has offered on my tilt front end-got an electric actuator (ball screw) 6" travel and its almost installed. I now need a switch that can reverse the polarity so I can make it go up AND down-the actuator has 2 wires and you just reverse the polarity to switch directions-any suggestions or websites for a dash mounted switch?
Thanks again
~TIM~
Old 10-23-2002, 07:46 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Get a power window switch at the junk yard. They switch the polarity jsut like you want. Wide variety of styles to choose from.
Old 10-23-2002, 06:18 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
Talking
willys' idea is good, but make sure that the switch that you get can handle the current going thru it.
JB
Old 10-24-2002, 11:49 PM
Last journal entry: Some pics
Post
You might even try radio shack or other similar store for your switch needs. Should have something that would work for the current.
Old 10-25-2002, 06:35 AM
Post
I used a rear power window switch for a station wagon. Works great to run the hydraulic pump to lift my tilt nose.
Old 11-12-2004, 01:02 PM
RELAYSSSSSSSS
I CAN'T STRESS ENOUGH THE USE OF RELAYS. LESS CHANCE OF A FIRE FROM RUNNING WAY TO MUCH AMPS. THROUGH A SMALL WIRE. IF ON MANY APPLIANCES IN YOUR AUTO YOU DO NOT USE RELAYS YOUR SWITCH LIFE MAY BE SHORTENED BY AS MUCH AS 90%
GOOD LUCK
Old 11-14-2004, 11:31 PM
Old enough to know better
You are looking for a double pole, double throw, center off momentary switch Any decent electronics supply house will have several different styles. The actuator wires will go to the center two terminals. Plus and minus will go to both ends but reversed on one end.
