tilt hood padding - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2002, 01:15 PM
jniolon's Avatar
Talking tilt hood padding
I'm doing a tilt front end on my truck and am looking for some type of padding to use between the hood and the cab cowl.Since this will show everytime the hood is open I want something that isn detracting from the look of my truck but will offer some protection from wear where the two pieces rub together...
any suggestions guys... some of you 3 piece hood guys should have some good ideas...
I've got about a 1/4" to use and maybe 1" wide
TIA
john
<img src="confused.gif" border="0">
Old 03-14-2002, 02:22 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Post
I saw a 39 Dodge pick up and the hood welting that the guy used was of all things, nylon webbing. Now get this it was nylon webbing like they use for dog collars, dog leashes and horse halters and reins. This material can be bought around here at any feed and farm supply store. It comes in colors, neat, the truck that I saw it on was yellow. so he used yellow webbing. It looked good and did a good job. I am going to paint my 30 Ford coupe yellow so I am going to do the same thing.
Old 03-13-2003, 09:28 PM
Post
some nice 1/4" thick tanned leather could be used and held with a brass strap or screws rivits? just a thought {wish i could spell better}
Old 03-13-2003, 10:03 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
I use 1" wide Velcro. Just use the furry side, not the hooks side. It comes pre-glued, just cut and press it in place! Nice and soft and very durable.
Old 03-14-2003, 02:51 AM
awsum34's Avatar
Post
I use black rubber buttons. you can get them to mount in holes or glue on or stick on..
A hardware store sells something like the stick on ones. but there clear. about the size of a dime
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 08:14 AM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 09:20 AM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
