tilt steering 90GMC pu. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2007, 02:20 AM
my gmc pu tilt steering is coming apart . I would apprciate info on tear down & putting back together. 90GMC K1500 PU.
Old 02-28-2007, 02:25 PM
fast68's Avatar
likes chevy trucks & boobies
its fun
you can do a google and find out
but it requires alot of tearing down
you have to remove the upper housing where the key lock sits in and then you have to pull both of the tilting pins thay are fun to pull out, are threaded so you have to find something to thread into them and pry them out i use a screw and a flat bar to pry the PITA things out
then you can finally get to the screws that came lose for the tilt
lock thread paste them real good or youll have to do it again soon
its a job, it will take around 2-3 hours
maybe more if bad stuff happens
good luck
Old 03-03-2007, 02:21 AM
http://buickperformance.com/tiltstee...lumnwobble.htm
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 07:07 PM
To repair tilt steering??? murrsue Suspension - Brakes - Steering 3 12-28-2006 11:02 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-04-2003 12:20 AM
tilt steering column?? 61wagonair Suspension - Brakes - Steering 5 07-07-2003 07:55 AM
tilt steering column sweethome18 Hotrodders' Lounge 4 10-23-2002 08:35 PM
