tilt steering wheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2012, 08:36 AM
tilt steering wheel
Own a1987 R-10 Chevy suburban need instruction on how to install a tilt steeringwheel with the least efford. Junkyard steering assembly cost me $200.00, instalation is set at $150.00. Is this reasonable? The assembly does not come with cylinder lock, any tricks to install?
Old 01-13-2012, 09:08 AM
boatbob2
tilt steering wheel,,,,,,,,
IF there is a pick-a-parts around,go there,and get the column and wheel,i just got one (complete) for $40.00,but i had to have a key made for it...
Old 01-13-2012, 09:57 AM
ogre's Avatar
the 'Duracell Project'
i picked up an 86 steering column for $35 w/tilt and a key
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 07:07 PM
Wiring GM Tilt Steering Wheel Column texapache Electrical 7 10-15-2010 09:35 PM
Loose steering wheel on GM tilt column, how to fix ?? NASCAR314 Suspension - Brakes - Steering 17 01-11-2009 08:20 PM
66 Oldsmobile tilt-telescopic steering wheel koooool Suspension - Brakes - Steering 2 12-18-2005 06:27 PM
GMC Tilt Wheel '86GMC Suspension - Brakes - Steering 7 10-21-2005 05:23 PM
