tilted car - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2012, 01:29 PM
bigblockragtop's Avatar
tilted car
Pulling up behind my car today I noticed it is leaning. I took out a ruler and the left side sits 3/4" lower then the right. I know what your thinking lose 100 lbs. It has coils in front and leaf in back all are new. I was thing of using spacers under the front drivers side coil to level it out. What do you guys think?
Old 05-09-2012, 02:53 PM
poncho62's Avatar
Wiki Edits: 5
Betcha, its a Nova or another GM of that body style...If it is, you are lucky it goes down the road straight, not dog legged....Have seen so many like that.
Most cars are not even all the way around, 3/4" isn't a whole lot.
Ontario Rodders
Old 05-09-2012, 03:48 PM
Well it is a Camaro but that did not really help answer my question though. I guess 3/4 is not much but was thinking it would be nice if it were level.
Old 05-09-2012, 03:56 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Is it the front or back or both on the side that is off ? what yr camaro is it ?
Cole
Old 05-09-2012, 07:23 PM
67 Camaro and the whole drivers side is lower the front maybe 1/16 to 1/8 less than the back.
Old 05-09-2012, 09:14 PM
S10 Racer's Avatar
http://www.warsprints.com
This is some pretty accurate measurements that personally I would'nt worry about. If you really want it level, I would cut the coil spring on the high side before I would add a spacer to the low side. What kind of shocks are you using and are they new?
Old 05-11-2012, 10:28 AM
you mentioned that you put in new springs recently? how long ago and what springs were they?
the next thing you need to identify is it the front leaning down or is it the the other side in the rear pushing it up which will in turn cross load the opposite corner.
If you installed new rear leafs as well... I would lift the car up, loosen up the shackle bolts with the car in the air... then set it on the ground and tighten em back up. remember, especially with poly bushing hardware not to over tighten which causes it to bind up.
tilted motor and tranny--oil out flywheel cover? rustycarr Transmission - Rearend 4 07-03-2011 01:49 PM
engine is tilted back 0pyders Engine 6 01-01-2011 07:11 PM
tilted trans 61bone Transmission - Rearend 7 09-03-2009 02:50 AM
Can an automatic trans operate tilted on it's side? Arrowhead Transmission - Rearend 31 11-30-2007 09:48 PM
someone has to remember- 90's custom car that looked like a fighter plane & indy car lowROLLERchevy Hotrodders' Lounge 12 04-06-2006 12:21 PM
