tilted trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2009, 09:37 AM
Last journal entry: frame build
tilted trans
I've noticed this for years, but finally decided to find out why. Can't say as I've ever seen a vehicle that didn't have the trans tilted to the drivers side. I could see having the mount tilted to counteract engine torque, but why the trans?
Old 09-02-2009, 09:43 AM
NEW INTERIORS's Avatar
Set no limit's on yourself
Not sure I'm on the same page here...
Old 09-02-2009, 09:52 AM
ericnova72's Avatar
More for Less Racer
I don't know what you are talking about either, engine and trans are always level side to side on any RWD car/truck I've ever seen with the exception of the weird 15° tilted T-5 manual trans in the 3rd generation Camaro/Firebird.
Maybe you need to get your eyeball recalibrated??
Old 09-02-2009, 10:23 AM
All of mine, are level...
Old 09-02-2009, 10:45 AM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
Worn motor mount on the drivers side?
Old 09-02-2009, 11:37 AM
Trannys not on the level
Some GM vehicles from the 50`s had a 4speed hydro that was tilted for clearence ,of what I`m not sure. I had a Tork stick hydro,"POS" I might add and the small block Chevy bellhousing made it level. The tilted ones worked properly. Go figure.
Old 09-02-2009, 11:51 AM
WDCreech's Avatar
Grumpy Old Goat Herder
I know exactly what 61bone is talking about. I still have a couple of old Pontiac bell housings from the early 60s. The transmission tilts toward the drivers side, with the engine level.
Old 09-03-2009, 02:50 AM
Wiki Edits: 85
Some transmissions do tilt to the side.
And so do some motors, Slant 6 Chrysler for example.
4x4 1994 Trans problems ???? sinlow1980 Transmission - Rearend 2 07-16-2007 06:37 PM
4t60 Trans Question david hill Transmission - Rearend 1 04-10-2007 08:58 PM
Allison Trans deseldr Transmission - Rearend 5 10-19-2003 07:45 PM
Fine Metal in Trans (NEW) bigjoedo Transmission - Rearend 1 08-09-2003 01:23 PM
Fine metal in trans bigjoedo Transmission - Rearend 21 07-27-2003 11:50 PM
