Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tilton button flywheel info
Old 10-05-2012, 03:14 PM
Sukhoi Sukhoi is offline
fro sure I value my feet, I have seen accidents from crappy made flywheels, as am not going to do it by myself, I know someone that makes flywheels, but he used to make normal flywheels, he is not used to deal with triple plates, as I showed him the photos, he just wanted to make sure if it should be flat or not, as he suggested to make it to be able to bolt on the same area on the crank, I liked the idea, it will be like 2 different pieces connected to the crank by bolts, so I think it will be safe, as I will do some heat treatment to the button, so what do you think?!
