Time For 302W. In Ford Courier. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2006, 07:54 AM
AmericanPackMule's Avatar
Last journal entry: Adolessent J.R.
Anyone here done that yet?
Old 09-26-2006, 08:03 PM
Kruzin Karl
Does a 327 SBC into a Dodge D-50 (Misubishi product) mini truck count?
Some of the most fun I've ever had was driving that truck. Go for it!
Old 09-26-2006, 08:06 PM
poncho62's Avatar
Wiki Edits: 5
I am sure it has been done..........
About the 327........they have been put in EVERYTHING....................
Old 09-26-2006, 08:34 PM
Time for 302W...
I'm useing my 302 Granada - From my '75 Pinto. With the Granada Rear End. (FIT PERFECTLY)
I'll use the Granada C-4 But will have to check the Courier Rear End. I Have a '70 Merc. & '76 Ranchero Rear Ends To use. Rim to rim to U Joint.
The '76 Ranchero has 2.75:1 / '70 Unknown.
In the Ranchero with 460 R. V. Cam /C-6 Thurmo Quad ~ Passing gear From 55 M.P.H. Pinned my back to the seat.
I have a 4 bbl Manifold for the 302 With 750 Holly.
I wonder How the Exhaust & Stering Box will work.
If I find out in 2 Mo's. I'll send Pic's
Old 11-19-2006, 01:32 AM
cheech beach's Avatar
Last journal entry: Cheech Beach
I put a 302, c4 in a 76 ford courier,I got the motor mounts,radiator, and headers from a company called chassis engineering. The stock rear end held up fine, but the brakes wouldn't slow this beast down.The headers went through the the fenders and limited my steering.I also used a remote oil filter due to frame clearance issues. This was about 20 years ago.
Old 11-19-2006, 08:03 AM
woodz428's Avatar
Troll Hunter
I have seen one in a Courier chassis, but it had a Model A body sat on it, so it probably had a different engine location. I have to say that it was a sweet swap(body and engine) and is worth considering for anyone that wants a fairly inexpensive rod build...gives IFS and Discs up front with no alterations.
Old 11-20-2006, 08:12 AM
Irelands child's Avatar
[QUOTE=AmericanPackMule]I'm useing my 302 Granada - From my '75 Pinto. With the Granada Rear End. (FIT PERFECTLY)
Rear End. I Have a '70 Merc. & '76 Ranchero Rear Ends To use..
These are probably 9" rears
The Granada, depending on year, time of the day, phase of the moon, or whatever reason, usually had an 8". The 6 cylinder cars were (usually) 3.40 for the 200cid and 3.55 for the 250cid engines w/standard. They also occasionally had a Chey style, spread and dump out the back style WER 8.7"/2.47 ratio that was a POC for your useage (I had a '76 V8 Granada parts car that had one)
Not much better SBF trans than the C4.
Dave
Irelands child
Old 11-20-2006, 02:28 PM
Wiki Edits: 31
If the granada is a 6cyl 200 CI, than your transmission will not work, as the bellhousings are diffrent
Old 11-20-2006, 03:03 PM
There are several different bell housings that will take a C4 from a 6 to a V8 - but not a C5 or FMX. A C4 is a 'universal' Ford transmission. There are several websites that describe the differences
Irelands child
Old 05-29-2008, 12:45 PM
[QUOTE=cheech beach]I put a 302, c4 in a 76 ford courier,I got the motor mounts,radiator, and headers from a company called chassis engineering. The stock rear end held up fine, but the brakes wouldn't slow this beast down.The headers went through the the fenders and limited my steering.I also used a remote oil filter due to frame clearance issues. This was about 20. I have a 74 ford courier which I would like to put a 302 in do you think you could give me some information regarding this swap. This is my first time posting on forums so I would appreciate if you would email me this information at bransdonstowell@yahoo.com
Old 05-29-2008, 02:00 PM
302 courier
I am new at posting on forums so bear with me but I have a 74 ford courier that I'm planning on putting a 302 in, could asnyone give me information on this swap and how to do it. thanks
Old 05-29-2008, 02:44 PM
302 in Courier...
TAKE OLD ENGINE & TRANS & Radiator OUT! Put 302 & C-4 ( Bolted together) "Long Block" With 302 Engine Mounts. In. Back of engine No closer to the Fire wall than 3". And Down as low as you can go with at least 1" From Stering Arm Stuff. Then Build - to make Engine mounts Work. Than Make Room For Big Radiator. Than Build To Make Work...
Old 06-03-2008, 11:09 AM
I would sure like to know more about that combination... Do you recall the year of the Courier? How well does the Model A front end mesh with the Courier? I have a 31 truck body, in the family since 1934..
46 ford p/u model # ( WRONG ) ? biglee550 Suspension - Brakes - Steering 19 03-17-2008 08:45 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 05:29 AM
T-5 transmission codes needed xntrik Transmission - Rearend 4 09-06-2005 09:09 PM
Ford Flathead to Ford automatic c4-kit? bigjim Engine 4 01-05-2005 02:11 PM
1992 ford f150. have cam problems big time cgreene Engine 2 05-02-2003 02:27 PM
