time to buy a bumpstick, opinions please - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2005, 08:28 PM
well i'm at the point where i am ready to buy myself a new cam. has anyone heard of predator cams by midway? if so what can you tell me about them. good or bad. looking at a cam from them with 228 @.050 and about 540 lift. rpm range 2500 - 6000 hydr roller retro fit. also been looking at comp cams 224 @.050 and 525 lift. rpm range 2000 -5500. or comp cam 230 - 560 lift.
i think that the 560 lift is too high but i prefer the operating range.
the car is 3800 lbs camaro, 355 sbc, 4:10 rear, 27" tire, 9.5 cr, air gap intake, 2500 stall, not sure on carb, i have a 600 and a 750 holley both vac sec, th350 with manual valve body, ported vortec heads, flow rates comparable to e-tec heads, 600 lift springs, ive 82%, car is used for street/strip. looking to find a cam that will maximize my power output. with this set up should i be going for the 2000-5500 rpm range or the 2500-6000 rpm range. thanks for you're input.
keith
Old 05-19-2005, 08:38 PM
smallblocker2's Avatar
L79 327 5SPD S10 '65GTO
With your compression, I'd stick with the 224-maybe 230. Sounds pretty close. try for a 108deg. LSA instead of a 110, and install it on a 104-106deg int. centerline.
my .02$
Old 05-19-2005, 08:52 PM
Bumpstick's Avatar
Hammer and a torch
Sorry I aint for sale
That Hyd roller retro sounds very interesting for your current setup...
Old 05-20-2005, 12:49 AM
predator cams?
anyone heard of or used these cams. any info to share would be appreciated.
thanks keith
Old 05-20-2005, 05:10 AM
I'm currently running their 67S grind. 45k miles, 100 passes and no problems. As far as power goes, it's as good as any of the name brands I've run in the past. Dan
Old 05-20-2005, 08:37 AM
thanks for your input, i am trying to make a decision now as i will be in myrtle for a week and would like to order something now so that i save a little cash$$$.
Old 05-20-2005, 05:27 PM
I know nothing about the predator cams, but ordered a Comp Retrofit Roller a few years back. They were willing to do custom grinds, using standard lobes, at no additional charge. I ordered one of the "extreme energy" lobe profiles, with the same lobe on the intake side as the exhaust. I did this because my AFR heads flow extremely well on the exhaust side, so I didn't feel they demanded a dual pattern cam. The point is that you might want to consider a custom ground cam that allows you to not only choose the intake side lobe, but the exhaust and the LSA as well.
And, perhaps Predator will do this for you too. Just offering an idea based on the great service I felt Comp gave me. You might want to try a 'puter dyno. I ran hundreds of runs with different "grinds" in EA3 before I ordered my cam.
Good luck. Let us know what you decide.
PatM
Old 05-20-2005, 07:48 PM
acr acr is offline
Take a look at Herbert Cams at www.dougherbert.com. He is the son of Chet Herbert whodeveloped the first hot rod roller cam back in the 50's. His prices are very reasonable & service is excellent.
Would you buy the Hot Rod or a Diamond for Your Girl? Tell Us! prismstar Hotrodders' Lounge 2 06-04-2006 05:21 PM
desperately seek opinions for carb choice txsfld Engine 53 11-22-2002 04:08 PM
Time Delay Relay Modification Thomas E. Cummings Jr. Electrical 7 10-28-2002 07:59 AM
Time and time again johnsongrass1 Engine 3 10-26-2002 11:16 AM
Carb Time. Croz Engine 2 08-21-2002 11:03 AM
