Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Time frame to clear coat
Old 09-23-2005, 06:16 PM
Centerline Centerline is offline
Wiki Edits: 49
Go here and read the "P" Sheet for the paint you're using. (Click on products, then Nason and you will see the product data sheets for all Nason products.) It will tell you how long you have to shoot the clear. It will also give you mixing instructions, spray pressures, drying time etc, etc.
