time limits on post edits ? - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders Site Suggestions and Help
Old 04-05-2009, 12:15 AM
fast68's Avatar
likes chevy trucks & boobies
never noticed until tonight but there is a time limit on howlong you can edit a post/thread ?
if so then how long is this time limit
thanks!
Old 04-05-2009, 06:48 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
If you have registered, you will be able to edit and delete your posts. Note that the administrator can disable this ability as he desires. Your ability to edit your posts may also be time-limited, depending on how the administrator has set up the forum.
To edit or delete your posts, click the button by the post you want to edit. If your post was the first in the thread, then deleting the post may result in the removal of the entire thread.
After you have made your modifications, a note may appear, which notifies other users that you have edited your post. Administrators and moderators may also edit your messages but this note may not appear when they do so.
Old 04-06-2009, 06:01 PM
fast68's Avatar
the problem is that some older posts dont have an edit button
thats why i was inquiring about what the time limit is
thanks
Old 04-06-2009, 07:19 PM
powerrodsmike's Avatar
Wiki Edits: 161
If I remember correctly it's about 7 or 10 days.
Later, mikey
BE different....ACT normal.
should Lounge posts count towards post total? Jon Hotrodders' Lounge 107 10-20-2004 07:42 PM
two-wire alternator - solved REALLY THIS TIME bullheimer Electrical 3 08-23-2002 12:14 PM
