time for the rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2010, 05:49 AM
hey everyone i have a 1977 pontiac 400cu #500577 block im looking to rebuild. the crank, lifters, and cam look to be in good shape. the 6x#8 head are pretty well done. the intake is still "decent". oil pan is good and valley cover is good. the pistons are in good shape but are badger replacements. im looking to do a nice rebuild to end up between 400 and 450hp. replaceing everything isnt a big deal. i would just sell off all the good parts if replaced. i guess what im looking for is a parts build list. anyone with experience with these blocks with any build lists or help would be appreciated. im planning on having 3.73 gears inthe back and a 700r4 tranny.
Old 10-20-2010, 03:11 PM
Dirty Biker's Avatar
Bold As Love
Is it not running well now? Why the rebuild? Leaking/burning oil? Low compression? Low oil pressure? Knocking? Just curious here, if it runs fine now I might just start with a good torquer cam to take advantage of that beefy poncho 400 low rpm potential. Buddy of mine had a 400 pontiac and stuck an rv cam in it, he said it was insanely fast stoplight to stop light, and actually still got pretty good mpg.
Old 10-23-2010, 10:09 PM
well the bearings that connect the pistons to the crank are pretty worn, and the heads need a complete rebuild. so i figured i would do the whole thing while i was in there
Old 10-23-2010, 10:35 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Do a search here for "pontiac build", and maybe PM WD Creech here, I knew him when I lived in Alaska...he is THE Pontiac man.
Here's one link: Pontiac 400 build.
Semper Fi
Old 10-23-2010, 11:20 PM
Semper Fi
AYE! Glad to know that post is going to use! Believe me man, there is A LOT of VERY good info there! Sadly you dont have the "best" block, but you can still make some good power with it I know that is a long post but if you read through it all you will get a good idea of where to start heading
GOOD LUCK!
Old 10-26-2010, 05:16 PM
ponchopower48's Avatar
im rebuilding a 74 pontiac 400 right now do u you guys think the heads on that are any good?
Old 10-26-2010, 05:21 PM
To answer any questions about cylinder heads, here is a link to all factory pontiac cylinder heads.
http://www.wallaceracing.com/head1.htm
Old 10-26-2010, 05:24 PM
thanks appreciate it
first time rear-end rebuild biscuitville Transmission - Rearend 4 02-24-2010 09:12 PM
Its Time..... ZMaster Introduce Yourself 3 09-11-2006 11:28 PM
Time for a rebuild......... 53_belair Engine 1 08-14-2006 08:32 AM
Time window after primer,body filler, color ,clear BIG DOG Body - Exterior 3 07-20-2006 09:13 PM
Time for a rebuild? 2wld4u Transmission - Rearend 2 10-25-2003 05:16 PM
