Time slip? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2012, 12:02 AM
396chevelle's Avatar
Time slip?
Ok, Just wondering if anyone would take a look at my time at the track to see if my goal is possible! I only ran it twice. I would like to run atleast a 6.99 or 7.0 in the 1/8th mile with this full trim chevelle. 1.7387 60ft---
4.9873 330ft---6.7510 ET @ 594 ft----(1/8 mile ET 7.2731)----86.19 MPH
Would a lower 60ft time get me to the 6.99 or 7.0 goal? Still needs some fine tuning, but I'm still happy with it. Seems to run pretty good for a street car. Thanks!
Old 04-21-2012, 03:53 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
A lower anything will get you closer to your goal...
Semper Fi
Old 04-21-2012, 03:59 PM
poncho62's Avatar
Wiki Edits: 5
What rear gears are you running, RPM through traps?
Old 04-25-2012, 09:22 PM
Im running 4.10 gears, but honestly I just ran the two runs and really did'nt pay attention to the rpm's at the end. I have my rev limiter set at 5,900 and it was'nt hitting it. Really not sure! I'll have to pay attention to that next run. It is mainly a street car and has a 26" tall rear tire. If that helps any.
Old 04-25-2012, 09:41 PM
The mph seems a low for the et to me! i would think 94-97 mph. 1.7xx 60 foot did it spin at the start, if so get it down to 1.5x and i would think you are real close to 7.00.
Old 04-25-2012, 10:05 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Get slicks on it. Your 60' time doesn't jibe w/the ET, either spinning too much, wrong stall or your launch technique needs work.
Also, most guys will over rev before shifting. Be sure to hit the shift points that you have calculated for the engine's power band- shift just past the HP peak so the rpm drops down into the meat of the powerband. If the engine wasn't dynoed, this will take some trial and retrial to find the sweet spot. Use a shift light. Short shifting, while usually being less often a problem, will still ruin the ET, too.
Old 04-26-2012, 08:33 AM
It spun very little, but I'm sure thats enough.
Old 04-26-2012, 08:43 AM
I did hit the rev limiter for a split second on the last/best run. Peak power on dyno was around 5,500 so I shift at 5,900. I have a 496 with a turbo 400 and 3,500 stall and 4:10 gears. Probably need to run it a few more times and work on a little better technique like you say. Thanks for the replies!
Old 04-26-2012, 01:29 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You should try shifting closer to 5500, like just past, the torque and gear ratio will help you a lot.
converting transfer case np203 from part time back to full time blade12376 Transmission - Rearend 1 12-05-2011 07:53 PM
slip yoke doesn't (slip) on... markzepp820 Transmission - Rearend 14 04-29-2008 01:29 AM
my time slip oldsmo Engine 11 07-29-2005 08:12 PM
need help on understanding time slip from drag strip 69elcaminoss General Rodding Tech 12 04-18-2004 12:52 PM
anti slip or no slip Terry411 Transmission - Rearend 2 05-01-2003 04:05 AM
