You never said what year and set-up you have. Most Fords have what they call a 'spout connecter' that has to be unplugged before you can check base timing. While this connecter is intact the pcm controls the timing and you cannot set base timing if it's electronic ignition. You have to unplug it and then start the engine to set the timing. But with no real information about what you have it's hard to help.
Your right, However, after crawling under the truck I found the mark at an estimated 90' around the balancer. the computer should'nt be advacing the timming that far at IDLE. Today I'm starting from scratch so that I know exactly where the timming is. Thanks for the input
