time to upgrade pushrods - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2013, 03:15 AM
I need some affordable pushrod recommendations for this vortec headed 383. Spring pressures are 130# at the seat, around 340# open. I don't think I should chance the stockers, even though the geometry is real close. Summit has a special deal on TFS pushrods right now. Anyone have any opinions on these? Are chromoly 5/16" plenty strong, or will 3/8" rods fit through stock holes? Too late to enlarge holes, as intake is installed.I also have some concerns with the mid-lift theory. Jim says use the roller tip axis, not the valve tip. I notice some roller rockers (mine) have a rather large (1/2 ") roller tip, while others have a considerably smaller dia. tip. Should this factor in when measuring? A larger roller would automatically equate to a longer pushrod, correct? Wouldn't a larger roller also leave a wider footprint on the valve tip, ie, a larger contact patch much like a larger tire does? I've got a nice footprint (.050") just slightly exhaust side of center, but at mid lift, trunion axis to valve tip is 90* to stem, but I have to go almost full lift to get axis to axis at 90* to valve stem. I am losing some accuracy because I'm not using a solid lifter for measurement. Any thoughts?
Old 02-11-2013, 06:30 AM
engineczar's Avatar
I've used several sets of TFS pushrods on circle track engines turning 7k with similar seat and open pressures with zero failures. For the money they're a bargain.
3/8 diameter is a nice upgrade but whether or not they clear is different from engine to engine and head to head.
BSE Racing Engines
The Following User Says Thank You to engineczar For This Useful Post:
flyingputz (02-11-2013)
Old 02-11-2013, 06:52 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
No guide plates? The stock Vortec pushrod hole is ~7/16", so you should be OK using a 3/8" p-rod, but this still needs to be checked because of variations in castings and manufacturing. If you can, get hold of a 3/8" p-rod and try it in each position- int. and exh, both sides. The problem is, w/o the engine running you can't see where the p-rod actually rides. And what you do not want is for the p-rod hole in the head AND the rocker arm's tip to both try to guide the p-rod (assuming self aligning rockers). But you still should be able to get a good idea of whether there looks to be a problem or not.
You can use a thick wall (0.120") 5/16" p-rod, but they wouldn't be the ones you're looking at now. And I have heard a 3/8" p-rod at 0.060" is more resistant to flex than a 5/16" p-rod at 0.120"...
You really need a solid lifter w/the same dimensions between foot and p-rod seat (or a hydraulic lifter filled w/grease, or tiny stacked washers) to do your measuring with. If the lifter's compressing, that skews what you're seeing.
The Following User Says Thank You to cobalt327 For This Useful Post:
Time for a distibutor upgrade! tobyj17 Electrical 10 10-02-2012 08:42 PM
converting transfer case np203 from part time back to full time blade12376 Transmission - Rearend 1 12-05-2011 07:53 PM
time to upgrade gto_ron Body - Exterior 2 04-11-2010 04:39 PM
time to upgrade spray gun benchracer1 Body - Exterior 8 02-10-2010 09:51 PM
First time upgrade question SS Power Engine 1 07-12-2003 03:34 AM
