timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2007, 09:43 AM
timing
I got a 1975 olds 350 all stock. Timing is set at 12 degrees. That sound right? Engine sounds great. I was just making sure it was set correctly.
Old 05-22-2007, 02:27 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
12 degrees initial sounds about right for a stock 350..
Be sure it does Not ping on load or throttle and you should be good to go..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 05-22-2007, 02:35 PM
Thanks Doc
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
BBC Timing Top Rod Hotrodders' Lounge 4 11-13-2007 10:48 AM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 01:35 AM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 07:52 PM
BBC Timing Top Rod Engine 0 06-09-2002 08:29 AM
