timing 14 to 16 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2007, 04:30 PM
timing 14 to 16
I was wondering what would happen if I bump timing from 14 to 16 what would the effect be, I know the cam will do it. I can experiment but it is a pain with the mallory I have and it is raining today. The car runs fine at 14 but would 16 give it more getup of the line? I should have given it more stall 2500 need 2800 or 3000.
355 trickflow heads 62cc 195 2.02 1.06, 480/492 228/234 110. holley 750 rpm airgap. 36 total
Old 10-07-2007, 05:28 PM
yea
I have the 4.11 but not the stall. I would experiment but to do the mechanical timing with the mallory I have to almost completely take it apart. It is easier to do with it out of the car. Does not sound that but but I drive the car to and from the strip 120mi. I know complain complain complain.
Old 10-23-2007, 08:30 PM
chevy_power427's Avatar
Fuel flows through my veins
I could also simply ping. My car is set up a 14, if I give it 16 initial, it's too much...depends of your compression.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Vacuum adv.. underdog305 Engine 58 01-30-2007 12:19 PM
pontiac timing Blob Engine 5 06-24-2006 06:54 AM
What's a good timing curve for a 4100lb car? Malibu73 Engine 3 03-04-2006 01:51 AM
Timing problem - Help MTMike Engine 1 11-13-2002 02:07 PM
