timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2009, 06:00 PM
SonnyFaust's Avatar
timing
ive got a 350. with an elecrtronic ignition,bored 30 over,272 cam, im trying to set the timing and i put a timing tab on it and put white out on the mark on the harmonic balancer and the mark will be an inch away from where it needs to be and ill turn the distributer and it will get closer to it and then it will die ill have to floor it to start it and it sounds like crap. is the distributer off a tooth or something. any ideas
thanks, sonny
Old 06-14-2009, 06:18 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Did you bring it up to TDC before you marked the balancer? or did you just install the pointer and mark it where it was at then? Cole
Old 06-14-2009, 06:33 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
First, determine that the engine is at TDC when the balancer mark is at "0" on the tab.
Next, if you are using a vacuum advance, it needs to be disconnected and the vacuum line plugged.
Old 06-14-2009, 06:44 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
As Cobalt said X2.
Also it may have a 'timing' connector that needs to be disconnected.
Depending on what vehicle this is, will help us diagnose your problem better.
Old 06-14-2009, 08:10 PM
SonnyFaust's Avatar
i have never done this before there is only one mark on the balancer. it is a line going all the way across it. i had it lined up with the timing tab.which is set at 4 degrees.it is a 1965 chevy pickup. it has no harness only the wires it has to to start it. i am not sure what year the engine is. it does have the vaccum advance. i did have it plugged. but do i plug the carb where the hose was connected. and is it possible that the timing gears are mabe one tooth off. i assumed the #1 piston was at tdc when the mark on the balancer was lined up with the timing tab. i stuck a screwdriver in the sparkplug hole and it was touching something i believed to be the piston. i just got the truck a month ago. im only 18 so if i sound like an idiot its just because im just getting into this. Thanks
Sonny
Old 06-14-2009, 09:01 PM
My 2 cents worth
Wiki Edits: 3
Sonny; We are just trying to help.
First, and foremost, find a manifold vacuum source, and plug in your vacuum advance to it. Your idle speed should raise, and smooth out, if not the vacuum advance is bad.
If it still has 'points and condenser' check the point gap, or dwell. This will change the timing. Always adjust it first, then adjust your base timing.
Put the screwdriver back in the #1 cylinder, and watch it's movement as you turn the engine over by hand. The lower the handle drops the higher the piston is.
Remove your distributor cap, and turn your crankshaft over by hand both ways. Watch your distributor rotor for movement, it should move almost instantly with the crankshaft movement. Watch the timing marker line on the harmonic balancer, to see if it is anywhere close to #1 at TDC.
Just my 2 cents.
Old 06-14-2009, 09:07 PM
SonnyFaust's Avatar
i will do that tomorrow thanks for the help, may i also ask is it possible for the timing gears to be off by one tooth?
Old 06-14-2009, 09:11 PM
My 2 cents worth
Wiki Edits: 3
The test of turning the crankshaft, and watching the rotor, will tell you if the timing chain, and or gears are worn out.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Low buck 355 sbc not running correctly, wanting to much timing. ForceFed86 Engine 68 04-13-2011 12:35 PM
sbc timing question 350pano Engine 8 05-15-2009 10:30 AM
Timing Timing Timing bigcountry1009 Hotrodding Basics 6 01-20-2009 05:47 PM
Do I need vacuum advance? (Long Post) Chevy21 Engine 49 10-25-2007 12:51 PM
