timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2003, 11:21 PM
Question timing
i have a 86 cutlass that i have transplanted a Olds 455 it has a GM HEI instead of stock points type i do not know the firing order on the distbutor i've tried hooking it up like a chevy then like stock were is number one on the distbutor witch way does the distbutor set in it and Thank u All for the help much appericate
Old 06-11-2003, 10:56 AM
GearHead69's Avatar
'70 Chevelle '70 C10
Thr pontiac firing order is the same as GM 1-8-4-3-6-5-7-2 and the plug wires should be in a clockwise order. You can't get fire??? Remember the right side of the engine is 1-3-5-7 and the left is 2-4-6-8 starting from the front, you probably know everything but just thoughts. Do the plugs have fire to them? will it even fire?
Old 06-11-2003, 04:15 PM
dklong's Avatar
the big block olds 455 engine . the distributer turns counter clock wise the same as ford!!! the firing order is the same as the chevy and #1 cylinder is on the drivers side.
Old 06-11-2003, 05:14 PM
dmorris1200's Avatar
doesn't play well with others
As dk stated, rotor rotation is counter-clockwise and 1,3,5, and 7 are on the left side of the engine not the right. In the automotive industry the drivers side is the left side and the passenger side is considered the right.
Old 06-11-2003, 05:16 PM
Old 06-11-2003, 06:31 PM
GearHead69's Avatar
I'm thinking of standing in front of the engine and working on it, right-1357 left-2468, I guess I'm wrong...
Old 06-11-2003, 07:16 PM
It's the most common mistake there is. Don't feel bad, I've worked with mechanics in shops who've screwed that up. Ohh the fun we have with FWD cars.
