timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2010, 09:34 AM
timing
hello hotrodders im just getting back into this its been 20 years or so and i need help with timing c10 454 shorty mostly stock no smog cam intake and 750 holley with headers it runs great @ 3k but thats 80 mph what can i do
Old 09-19-2010, 10:04 AM
Greg T's Avatar
www.krusinklassics.net
What can you do about what? Does it not run below 3k? Are you saying that 3k @ 80 mph is to slow? Too fast?...
Old 09-19-2010, 10:56 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I was wondering, too. Started to recommend a 4.88 rear gear, but thought better of it...
We need to know what it is that you are having a problem with- like it won't idle or run at low speed, or you cannot get it to idle slower than 3K RPM, or??
Old 09-21-2010, 05:47 AM
my problem its a daily driver and I would like to be able to cruise at speeds lower than 80 she runs great up there and faster i know the rears are3:08 and the cam I put in its only .475 lift dur. around 220 I just can't get her to run good from 40 to 65 everything's rebuilt eng,trans, rears thanks if you can help!!!
Old 09-21-2010, 07:58 AM
sounds like you have ignition timing issues.
set initial timing to 15, total should be around 40 (with out the vacuum advance).
then plug the vacuum advance into a manifold source and adjust the canister for 10 degrees.
so, timing will be about 25 at idle (15 mechanical plus 10 from the vacuum advance).
you will need to get another vacuum advance canister. go to summit racing web site and get a canister that is adjustable or limit the amount of advance your stock canister has (mechanical stop).
then adjust the a/f mixture screws for best (highest idle).
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Low buck 355 sbc not running correctly, wanting to much timing. ForceFed86 Engine 67 04-13-2011 12:35 PM
sbc timing question 350pano Engine 8 05-15-2009 10:30 AM
Timing Timing Timing bigcountry1009 Hotrodding Basics 6 01-20-2009 05:47 PM
Do I need vacuum advance? (Long Post) Chevy21 Engine 49 10-25-2007 12:51 PM
