Timing for a 1992 Chevy 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2004, 06:51 PM
What is the timing degree I need on a 1992 chevy 350???
I just put the Edelbrock MPFI in and I don't have the fan guard anymore so I don't know where to time the engine at.
Gawd Please somebody help me!!!!!
Old 09-04-2004, 10:14 PM
lonewolf3197's Avatar
Chief Petty Officer, USN
Last journal entry: My Monte Carlo
My wifes 94 350 is 0* and my pops 1990 350 ( both TBI truck motors) is 0* also. I know they are not the same years as yours but it gives you a reference point. Just make sure the computer is disconnected from the distributor when you time it or it change by it's self.
Old 09-05-2004, 03:10 PM
unplug youe est wire(tan wire with black stripe) which is located behind the panel on the firewall on a 92. start the truck and set the timing. Factory timing is 0 degrees you can advance by 2 degrees at a time if you like until you fear detonation. I have mine at 8 degrees. Shut the truck off then reconnect wire and you are done.
Old 09-05-2004, 03:15 PM
Siggy_Freud's Avatar
Most setups like that you have to unplug battery before you plug the EST back in. Chevy's stock MPFI timing settings are normally set at 6. I have my base timing at 10. Play with it and see what works best for you.
Bringing history and technology together.
