timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2012, 01:34 PM
timing
I have a 327 chevy small block I put a thumper cam in it now i can't get the timing right. Could it have something to do with the distributor?
Old 03-26-2012, 01:39 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
I would assume it has everything to do with the distributor. You need to retime the distributor with the camshaft and rotating assembly to get the plug to fire at the correct time. What do you have the initial set at? What is the mechanical advance set to? If your not 100% sure on exactly whats going on under that distributor cap read this article..
http://www.corvette-restoration.com/.../Timing101.pdf
Does MSD make a timing control the actually advances timing? Gene1000 Electrical 15 12-15-2011 01:08 PM
Timing sbc corvette timing at 12o clock on both gears? 85 vette Engine 21 12-22-2004 08:23 PM
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 07:54 AM
Base Timing - Advance timing chevelle67 Engine 3 05-11-2004 07:45 AM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 01:35 AM
