Timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2012, 07:34 AM
Timing
Hey guys maybe you can send me in the right direction. While adjusting my timing on my sbc i set it at 8 btdc and the exhaust smells weird and smokes. The engine runs good at that setting. Which way will stop the smell?
Old 10-17-2012, 09:56 AM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
You should try and provide allot more info. First off tell us about the engine specs such as cam specs to start, is this a highly modified engine or basically stock setup? what type of distributor etc etc.
Smells weird means nothing, if the engine idling is creating allot of tear jerking unburnt hydrocarbons then more advance on the idle timing can help clean this up. Most mild to mid range cammed motors like more than 8 deg BTDC, but then again we know nothing about what you have.
Smokes? what is the color, blue black or white?
More info = more effective trobleshooting advice here.
Old 10-17-2012, 10:14 AM
Timing
Sbc 350 10-1 comp, 514 cam msd dist,making approx 425 hp ,750 holley. Thanks but i solved needed more advance. Seems ok now.
Old 10-17-2012, 10:58 AM
Custom10's Avatar
Ok good
If you have vacuum advance try running that on full manifold vac at idle, with a base setting of approx 18-22 deg timing + 10-12 more through vacuum advance and you'll have about 30 btdc at idle, this can make a world of difference and also allows for more effective carb adjustments cause you can back off the primary blades (main idle screw) to get the carb working more on the idle circuit rather than on the main or transfer side.
Old 10-17-2012, 12:36 PM
timing
Thank you. Running good now will try your formula hopefully it can get it better.
Old 10-17-2012, 12:58 PM
bigdog7373's Avatar
Of course it's fast
Check your mixture too. Even with the timing off it shouldn't be smoking.
What's the rest of your setup? 425 seems hopeful optimistic for a 350 Lol
Does MSD make a timing control the actually advances timing? Gene1000 Electrical 15 12-15-2011 01:08 PM
Help with timing Chain and timing cam install LXZ590 Engine 7 12-08-2006 10:01 PM
Timing sbc corvette timing at 12o clock on both gears? 85 vette Engine 21 12-22-2004 08:23 PM
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 07:54 AM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 01:35 AM
