timing - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-05-2013, 09:24 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
To lock the mechanical advance you remove a roll pin and turn the shaft 180 degrees and reinstall it w/the limiter pin (remove the bushing) in a hole instead of the advance slot. It's all in the instructions.
  #17 (permalink)
Old 01-05-2013, 04:12 PM
timing
well i got this engine to idle down to 900 to 1000 but surging alittle sometimes it will die sometimes keeps running tweaked on timing tweaked on carb but still have 22-24 degrees timing at idle with vacumn advance dis connected what do i need to do next
  #18 (permalink)
Old 01-05-2013, 05:11 PM
timing
this dang motor has been a mess slowly getting a hold on it just need to find out why its surging at idle from 900-1000 rpms is that cam doing that
Does MSD make a timing control the actually advances timing? Gene1000 Electrical 15 12-15-2011 01:08 PM
Help with timing Chain and timing cam install LXZ590 Engine 7 12-08-2006 10:01 PM
Timing sbc corvette timing at 12o clock on both gears? 85 vette Engine 21 12-22-2004 08:23 PM
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 07:54 AM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 01:35 AM
