Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Timing 355
Thread: Timing 355
Old 10-25-2012, 08:37 PM
1981zapper 1981zapper is offline
Originally Posted by bygddy View Post
Cam #'s, heads, intake, Carb.....etc etc.....more info needed.....but no, i doubt 5 month old fuel is "gone bad" .......sounds like you get the initial nailed down but to much total, a recurve would likely help, what plugs, gapped at what etc.....just more info.....a flyweight car may get away with more total, a 4x4 truck....not so much....just need to know more before everyone chimes in...
The engine is in a 1981 Camaro Z28, with a Turbo 350 automatic and 3000 Stall Converter,
like i said i have no engine specs, the pervious owner said he rebuilt the motor in the 90's and does not have any mileage on it, he said the compression is around 10:1, the heads casting #: 462624, its got the factory cast-iron intake manifold, Qjet carb, i'm running Delco R45TS plugs gapped at .45, i just changed the wires to Taylor 8MM Street wire, its a pretty radical cam in there,
