Timing 355 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-25-2012, 10:09 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
I know, what we mean is that checking for correct tdc and balancer tab accuracy ensures that your timing light readings are accurate, balancers can slip etc
  #17 (permalink)
Originally Posted by hcompton View Post
First problem your chip moduale says gm on it. You need an after market one. Stock one drops off at 5500 or so. If you dont already, buy a kit with recurve, moduale, coil, cap and rotor the works. Then google for hei setup usally you need to make several small adjustments for bigger cams. And usally all work toward restricting advace from mechanical and vacum and using more inital advance.
I wont go over all the steps here i have seen great stuff on the web for hei setups. With lots of good close up pix.
Not really the first step no......stock intake, 624 heads, and even if the cam is large by huge, its all done by 5500 with his set up....stock module is just fine.....the car ran fine, the the dist was removed and reinstalled, then he had issues....
Step 1 = find tdc and make sure balancer and timing tab make sense...then move on.
  #18 (permalink)
Old 10-25-2012, 10:12 PM
i have already done that, i made sure my 0 on the balancer lines up with the 0 on timing tab
  #19 (permalink)
Old 10-25-2012, 10:16 PM
Just because they line up, doesn't make it accurate ....
  #20 (permalink)
Old 10-25-2012, 10:17 PM
Custom10's Avatar
You need to get the #1 piston at TDC first right? using piston stop
http://www.crankshaftcoalition.com/w...op_dead_center
  #21 (permalink)
Old 10-25-2012, 10:18 PM
lol yes i made sure that the piston is accurate with the timing marks
  #22 (permalink)
Old 10-25-2012, 10:28 PM
i made sure that the piston is at TDC, i then droped in my distributor
  #23 (permalink)
Old 10-25-2012, 10:42 PM
Off a tooth maybe? Have you tried pulling it and reinstalling? Back to the start now, you said it was running fine before, but was that back in June? What I'm getting at is could the problem have been there last week but you hadn't driven it enough to know? If that's a possibility then you could be on track with a combination of bad gas, carbon build up, fouled plugs etc.....so, if its me, and I'm confident the dist is right, and the timing is right, throw new plugs at it, get some fresh good 92+ in it, set your timing conservitive, insert 80's Glam rock cassette tape, I reccomend skid row, and go drive the sht out of it....then try some more timing and see how it goes.....
  #24 (permalink)
Old 10-26-2012, 11:33 AM
Custom10's Avatar
Thats a good one, reminds me of that Mr. Lube commercial,,,canadian style 80's,,,my favorite,,,love the look on the gals face too haha
  #25 (permalink)
Old 10-26-2012, 06:45 PM
Now that i think about it, this summer i changed the filter in Qjet, and when i went to loosen the nut on the line, the metal line kinked and put a hole in it, so i cut the line back and put a rubber line on, do you guy's think that this rubber fuel line is collapsing at W.O.T?? especially on the bend?
need help with buddies 355 sbc timing!!!! 350vortec Engine 12 05-23-2012 09:02 PM
355 sbc timing help schottout Engine 2 12-12-2009 12:33 AM
SBC 355 Timing Question Fasazu Engine 7 10-16-2009 08:59 PM
SBC 355 Timing Question Fasazu Engine 1 10-14-2009 09:43 PM
355 update and timing question. Jared Engine 4 06-04-2003 04:26 AM
