like i said i have no engine specs, the pervious owner said he rebuilt the motor in the 90's and does not have any mileage on it, he said the compression is around 10:1, the heads casting #: 462624, its got the factory cast-iron intake manifold, Qjet carb, i'm running Delco R45TS plugs gapped at .45, i just changed the wires to Taylor 8MM Street wire, its a pretty radical cam in there, |
i bought the car in 09 and never had a problem with it pinging, but i had to pull the distributor, there was no timing tape so i didn't know what the pervious owner set the timing at, here is a pic of the engine when i bought her
![]() Here is a pic of the springs in the distributor, the rotor and cap looked all good
20 deg mech adv is on the high side, may want to try about 14-15 and bump the base up to 20 ish again. But if it is rattling at WOT then the changes to the mech limit may not matter. I see the vacuum adv is not hooked up so that is not the issue. Ensure he dist is really clean and the mech adv is free to move and wont hang up. Its got the heavy springs so the curve is not agressive
I am un wise to the ways of the qjet but it may be a lean AF ratio causing the ping issue. Check the fuel psi, filter and jetting + carb functions etc. If the motor is carboned up that can make it rattle as well. vacuum leaks?, the basics |
Well when I had it at 38* Total you can really hear it rattle at wide open but I find that the motor likes 15* initial and 36* Total it still rattles but not nothing like at 38*, I do not have the vacuum advan hooked up, the distributor moves free, I never had a problem before with the Qjet, I can tell you that the plugs are all black, when I pulled the plugs out I put my Camera inspector into the combustion chamber and you can see the carbon on the pistons, this engine does more idling more than anything, this year I only took her out once ![]() ![]()
I agree with Vinnie, doesn't sound like a real lumpy cam or anything, typical 268 sound to me. But if you pulled the dist, and this started after you reintalled it your going to have to go back to basics, find true tdc, get a timing tape on it and a dial back light and start from scratch....typical hei has 20 degrees built into it. But without knowing your initial is what you think it is your kinda guessing here....
If its full of carbon, and sits around that much, get the timing sorted out, your likely going to want to limit total to 34 or 35, get the highest octane pump you can get, and go drive the damn thing and clean it out lol.......good gas, and a little abuse (assuming its not rattling anymore with conservitive timing) will do wonders, once its de- carboned (is that a word) then you can sneak back up on the timing to see what it wants for maximum performance....
First problem your chip moduale says gm on it. You need an after market one. Stock one drops off at 5500 or so. If you dont already, buy a kit with recurve, moduale, coil, cap and rotor the works. Then google for hei setup usally you need to make several small adjustments for bigger cams. And usally all work toward restricting advace from mechanical and vacum and using more inital advance.
I wont go over all the steps here i have seen great stuff on the web for hei setups. With lots of good close up pix. |
| need help with buddies 355 sbc timing!!!! | 350vortec | Engine | 12 | 05-23-2012 09:02 PM |
| 355 sbc timing help | schottout | Engine | 2 | 12-12-2009 12:33 AM |
| SBC 355 Timing Question | Fasazu | Engine | 7 | 10-16-2009 08:59 PM |
| SBC 355 Timing Question | Fasazu | Engine | 1 | 10-14-2009 09:43 PM |
| 355 update and timing question. | Jared | Engine | 4 | 06-04-2003 04:26 AM |
