Timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2002, 05:32 PM
Unhappy Timing
Just purchased a crate engine 350 v-8 4 bolt main
330 hp (L 98 aluminum corvette heads) and an edelbrock carb. every thing else is stock.
Problem I do not know the right timing, heard between 8 -12 no answer from manufactor and car running hot over 220.New 5 blade alum. fan. can you give any help I will appreciate.Running out of time!HAHAHA
Thank You
<img src="confused.gif" border="0">
Old 10-05-2002, 07:13 PM
dmorris1200's Avatar
doesn't play well with others
Post
Are you sure timing is your problem? I have had my timing as high as 15BTC with no temperature side affects. And I would agree with what you said, 8-12BTC would seem like a good estimate.
BUILT FORD TOUGH
Old 10-05-2002, 11:36 PM
Post
Had a 350 like yours in a 71 Camaro(it had stock 2.02 heads) I rebuilt that motor twice and remenmber timing was exactly what you quoted. I never had a overheat prob with that car.
