Timing a 4.3 Chevy V6 carbureted HEI - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2014, 04:23 PM
I've got a 1994 Chevy 4.3 V6 which I've converted to carburetion. I'm ready to set the timing, but getting conflcting thread options on how it should be done. I'm using a Skip White 65K HEI distributor on a 4bbl 1984 truck manifold. There are 2 marks on the timing pulley. Some threads say to line up the first line and others say the second, as I turn the pulley clockwise. I'm also not sure of where the #1 cyclinder should be on the distributor. I start to get compression as the first mark passes. If anyone has one of these setups, I would appreciate any help. Thanksd, Tom.
Name:	distributor jeepster 001.JPG
Old 04-26-2014, 07:52 AM
Everything is HAMMER!
I remember how frustrated I was when I set timed my first distributor, but believe me it is something anyone can do. A simple Google search on "setting timing on a distributor" should give you more information then you need to do it properly. Also, I'm certain there is a crankshaft coalition wiki on setting up a distributor somewhere.
Old 04-26-2014, 09:48 AM
Northstar T's Avatar
Gone sailing
does it ping when driven? if not, keep advancing the timing until it does, then back it off 2 degrees and forget it.
Old 04-26-2014, 10:19 AM
Last journal entry: New Rev wheels and BFG KDW II tires
The only way to know for sure the timing mark is right on the money now that the engine is assembled is to use a piston stop. They can be made cheaply and fairly easily with an old spark plug. Follow the articles on the crankshaft coalition page.
http://www.crankshaftcoalition.com/w...op_dead_center
The #1 on the distributor should be the terminal on the cap that is closest to pointing at the #1 cylinder, drivers side front of the engine. Same basic setting as a sbc with two less terminals.
It doesn't have to be that exact one but that is the one the factory used as #1. If the rotor doesn't line up with that terminal when at tdc you will need to pull the distributor and reinstall it in the correct spot.
Old 04-26-2014, 05:52 PM
on 89 timing mark is the one on the left and the one on the right points to another mark on timing cover lower down
Old 04-26-2014, 06:46 PM
Thanks to all for the help. I should be able to set it now. Tom.
Old 04-27-2014, 09:50 AM
41'srfun's Avatar
Last journal entry: 41' finally has paint on it
I've got a 94' that was in a s10 Blazer. I had to replace the fuel injection spider assembly and when I tried to go by the marks on the balancer to drop in the dist. it about drove me nuts, because it kept backfiring when I tried to use either of the marks on the harmonic balancer.
I finally used a home made piston stop to find TDC. I placed a mark on the balancer with chalk, installed the dist. and it fired right up
Old 04-30-2014, 12:18 PM
Cars, Trucks, Boats
. Yes, even buying a piston stop tool is like only about $5.95... handy in case the outer ring of the harmonic balancer has slipped a bit on the rubber... or putting timing marks where they are easier to see...
Old 04-30-2014, 04:14 PM
I have the front fenders off now, so I am able to see the top of the number one cylinder with a flashlight. With the timing mark aligned I,m right on TDC. I should be good to go now. Thanks, Tom
Twin Turbo's on a Carbureted Small Block Chevy.. TheZaZ Engine 28 12-21-2014 05:26 PM
Carbureted Vortec HEI Timing GUITAR1989 Engine 3 08-28-2012 11:31 AM
set timing on chevy 454 with HEI 71Nova454 Electrical 5 10-12-2010 08:14 PM
timing on 350 hei Josh249cc Introduce Yourself 5 09-11-2004 12:13 PM
HEI timing stinky jinx Engine 6 05-31-2004 09:11 PM
